- 02 lx
what kinda WHP numbers will come after that install???
what EMS is used?MAMotorsports said:The Thumper kit is $4495 and comes with:
GT30R turbo.Dual ball bearing(your choice of 3037 or 3071)
Polished Turbo compressor housing
Jethot coated turbo hot housing
Tubular stainless manifold w/merge collector,external wastegate with EGR
Tial 38mm wastegate
Jethot coated Tubular manifold
2.5" stainless downpipe with double wall flex joint
Jethot coated downpipe
2.5" stainless mid pipe with O2 bungs
2- Spal 9" fans
1- Spal 12" fan
Fan harness'
3" stainless intake with X-stream style air filter
Large FMIC with polished cast end tanks
Tial 50mm blow off valve
Powdercoated cold piping(Black or silver)
Over flow bottle relocation bracket(polished or brushed)
Aluminum 3 port vaccum source(polished or brushed)
Silicone couplers
silicone vaccum lines
T-bolt clamps
Braided oil feed and drain lines
RyanJayG said:lol.... you sissy.... what happened? you used to be hard-core.
you shoulda stayed up till it was done... haha j/p
glad its going good so far.
azian6er said:pictures will come guys.... I had one **** hell of a long day. Kit isnt in all the way yet, but should be good to go tomorrow or tuesday. I still have to adjust the timing, run some more electrical connectors, install radiator, downpipe and midpipe and a few other things. I am beat to hell right now though so im hitting the sack.
More pictures to come tomorrow.
-Bryan
