pictures as promise!!! springs/shocks finally installed....sorted of...=(
udontknowjack
mazda mazdaspeed3
but houston we have a problem....the rear shock awrracing ship is missing something....bushing>? washer....so currently only front bilstein shocks are installed....along with ms springs kit.....!!
took her out for a drive on 580 freeway....theres hardly any different compare to stock set up...almost as smooth....but its a big step in performance with this bilstein/ms springs.....at least thats what i feel.....enjoy the pics
http://s171.photobucket.com/albums/u314/udontknowjack/ms springs kit and bilstein shocks/
What springs are those exactly? the regular Mazdaspeed lowering springs w/ rear camber links, It sayes in my catalog they only drop 15mm which is .6in? Bilstein shocks? where did you get those from? Does it look any lower, I cant tell from the pics for some reason! I was interested in a similar setup, so Im curious! Thanks
if u look down below....topic ms springs kit/bilstein shock....i answer most of your same question alrite....
ms springs said it only lower .6in...but i have see other ms3 owner with same ms springs kit...and its lower than 6in...but nonetheless the ride is almost as smooth....but it feel so much nicer....performance wise.....the bilstein shock is custom valved to ms3 spec.....but being the prototype...the rear shock is missing a bushing or washer if u can see the pic......will test the performance this weekend in scca national tour event at atwater.....
