Pics Of Upgraded Tmic
Rican219
MazdaSpeed 6
I finally had to do it..... Glad I did BIIIIG Difference! LOL
My Updated mod list:
8K Hids + Fogs, CP-E 3 inch DP, Custom 3inch Exhuast, SU Motor Mount, TWM Short Shifter, Full Gauge Cluster, CAI, HKS BOV, Eyebrows, All Hyper White LED lights on Interior, ETS Polished 3.5 TMIC
EMS Here I come!
Pics attached
Few More
And how does it feel from a seat of the pants perspective? I would assume the factor IC would cause a large boost drop between end tanks and the efficiency of this is much better as well. Less heat soak?
Do tell! My ear are dying to know!
Where did you get these?
<img src="http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=30860600&albumID=584676&imageID=4856004"/>
Well Butt Dyno says DAYUM!! Yes BIIIG difference. I spool faster heat soak issues for sure not a big problem.
I'm showing I can pull 18 psi then it settles down about 16psi and pulls from there in almost every gear. Sometimes I spool faster then I can shift (before the turbo drops off)
A MUST If you can afford it!
?? Not sure what the code is suppose to be
I was trying to use HTML to embed a picture of your 3guages mounted in the dash. I was wondering who installed that and where you got the kit?
Also, where did you buy it ? Cost?
I installed it. Bought the gauge pod at gaugepod.com I think it was like $50. The gauges came from Prosport.com.
I think it looks amazing. I tried going o gaugepod.com but it didnt work.
