Pics Of Drop?
can everyone that has stock wheels and has dropped there car please post pics of it? and how much it was dropped and the type of springs you bought?
thanks
Here is a pic before and after with the factory rims. I used Ground Control coil-over slip-ons. The first pic is all the way down and the bottom pic is with the factory springs.
I talked to someone today at SPool and they said that same thing. I will order a set as soon as they get back in stock. Looking forward to getting rid of the coilover pop.:)
What is the ride like in comparison to the Eibach and H & R?
Its very confortable, actually less harsher than both the H&R's and eibachs. In terms of harshness the H&R's are at the top of the list then eibachs, then the spool springs. And the handling is just phenominal. However if I had to choose between the H&R's over eibachs I would choose the H&R's they handle better and give a nicer drop than the eibachs.
Stock wheels with eibach springs. Lowers your ride 1.4 inches in the front and 1.2 in the rear. Click on the image link at the base of my 'sig' for pictures...
How many inches do the Spool springs lower our P5?
and if i get the MP3 struts would that be enough to handle the drop..cuz i know the stock struts will blow soon enough, especially in with NYC roads....
They lower the car 2 inches all the way around at all 4 corners
Yes you can use the MP3 suspension but it is not necessary
