MALLARD,
Thank you for the kind words. Though I feel, as you do, (that Rocketspeeds frustration should not have been taken out this way) he does have a reason to be frustrated.
I am addressing his issue directly in this thread.
Click Here
Boost sciences
I will address the community with info rather then throw the second punch.(fight)
The PERRIN Performance boost controller featuring a custom wound internal spring and ceramic metering ball, increases boost accurately over bleed type valves. The use of a ceramic ball decreases weight, improving response time for a crisp wastgate transition. An additional hidden bleed port eliminates any dangerous boost spikes.
Unlike bleed type valves, the PERRIN boost controller is specifically designed to delay any pressure signal from entering the waste gate. Spool up will increase insuring more boost at lower RPM.
Our products is not a metal tube with a ball and spring. We do not use off the shelf parts. We custom machine our body from 6061 aluminum. Special internal fluting maintain ball alignment within the oversized cylinder and allow accurate airflow.
Our custom wound spring maintains ball alignment and delivers the perfect spring tension.
The outer body is anodized to prevent corrosion. And assembled with O-rings and assembly grease for an airtight seal.
Adjustment is simply made by twisting the body without the need for any tools. Alignment marks on the body allow the user to accurately make adjustments.
Questions? let me know.
