Permanently turn off i-stop
Hello There...
The i-Stop function is actually really good. I have learned how to use it quite effectively. The trick is to learn how to activate it by using your brakes.
What I have found, is that the amount of pressure you apply on the brakes will determine whether the function activates. Try it. The lighter you are on the brakes, the less likely i-Stop will activate. It will just keep flashing at you on the dash. Just use enough pressure to pull the car up. You'll find the motor keeps running.
When you are at a set of lights for a long time, press harder and the i-Stop will kick in.
Try it.... It's all about the brakes...!!!!
