MAM 2.0L FS-DE Built Protege Motor
http://**************************.com/cart/images/tn_IMG_0491.jpg
Our short blocks are fully machined and deburred. When we build our motors we do the whole nine yards.
Our short blocks come with:
CP Pistons
CP Gold Ring Package
Oliver Billet Rods
Toga bearings
ARP Main studs
New oil squirters
New Freeze Plugs
New Oil galley plugs
We address the crank walk issuse by having a second thrust bearing machined and installed, we have the crank nitrated a second time, then it gets micro polished, line honed, square decked, bored, honed, plateaued, all oil passages chaffered, full block debur, and more! Their is a $500 core charge to be added
We do not simply bore & hone and put new rods in pistons in. Everything is done to spec and a full build sheet comes with our motors. The customer will know all tolerances and specs. Our motors are $2995, plus core. Freight Charges for this item are calculated based on weight.
$2995 ... then slap on one of their turbo kits.
