performance engine?
saitek
i want to give my protege ES some power, im thing somewhere around 250hp. now i looked at the FS-ZE engine, but those engine can only take 220hp before the internals need to be replaced, its not a performance engine, my stock 2.0l can take up to 230-250hp before internals need replacing. so my problem is who and what do i turn to for an engine that can handle the power or do i just have to over haul an engine?
Here...
search also.... :D
MAM 2.0L FS-DE Built Protege Motor
http://**************************.com/cart/images/tn_IMG_0491.jpg
Our short blocks are fully machined and deburred. When we build our motors we do the whole nine yards.
Our short blocks come with:
CP Pistons
CP Gold Ring Package
Oliver Billet Rods
Toga bearings
ARP Main studs
New oil squirters
New Freeze Plugs
New Oil galley plugs
We address the crank walk issuse by having a second thrust bearing machined and installed, we have the crank nitrated a second time, then it gets micro polished, line honed, square decked, bored, honed, plateaued, all oil passages chaffered, full block debur, and more! Their is a $500 core charge to be added
We do not simply bore & hone and put new rods in pistons in. Everything is done to spec and a full build sheet comes with our motors. The customer will know all tolerances and specs. Our motors are $2995, plus core. Freight Charges for this item are calculated based on weight.
$2995 ... then slap on one of their turbo kits.
thats actually my engine... CP 8:1 pistons... taken with a Canon A75 camera with mercury vapor lights in an overhead, warehouse like lighting setup.....
actually I took that pic at work, and for some reason it was a tad out of focus... maybe I smudged the lens, I forget, it was a while ago.
