PCV Valve location? 2010 M3 2.5l
Hey Guys
Trying to trace down a rough idle issue thats intermittent.
When in drive with the brake pedal down the engine will sometimes run rough, not too serious but you can feel it throughthe steering wheel and the seat,, its kinda of annoying.
Where is the pcv valve located? I would like to replace/clean it
Things i have done so far: cleaned the Throttle body, spark plugs replaced, cleans MAF, pulled - on batt and did the relearn idle process.
2010 mazda 3 2.5l w/ 73k
Any help is appreciated!
