PCV Valve Inspection - How strong should the vacuum be?
2019 CX-5 Touring
In the pre-purchase inspection on the 65,000 mile CX-5 I just bought, the technician said the PCV valve wasn't working and should be replaced. Since replacing it is a PITA I checked it using the workshop manual process (http://nema.club/2014wsm/workshop manual/n6w01/html/id0116zc800400.html). When I check the end of the ventilation hose, there is suction but it's not very strong - it will hold a small receipt but not a sheet of paper. How strong should the suction be if the PCV valve is working correctly? The only info I can find is not Mazda specific but it all says "strong suction".
if the check engine lights not on and everything's working ,how do you know something broken when everything is correct then ?
