Saskatchewan17
- 2008 TR Mazdaspeed 3
No. It dries quickly and it will not wipe away clear. I use it as a first resort whenever I am faced with overspray.
okee dokey... I didn't know. I would just try clay first though.
laquer thinner scares the hell out of me, i would be so nervous using it.
OP - Great detail shop 171-08 39th Ave Flushing NY. Its in queens, dont know how far into the island you are but they do awesome work. costs between 250 & 350 depending on how far you want to go with it
hope you have the whole day, cheapest detail takes 4-6 hrs, mid level 6-8 and the high end is by appt only
I've never had it take away either the clear coat or the underlying paint. Be it on a freshly sprayed paint job or paint that has been cured for much longer. Clear coat is not that delicate so as to simply wipe away. I don't know what else to suggest to you other than to try what ever method will not scare the hell out you to correct your paint issue.
Thanks a lot I will def try this if other options dont work. do you have a number for them?
(718) 353-2830 ask for steve, they do tints as well if you dont already have em place is called TintMax
First try Denatured Alcohol, works on cleaning lots of paints from different surfaces,clear coat friendly.
yea i just got it and its working great, gonna take a long time since on everywhere, and i am only doing very small section then wipe off the excess to be safe. I cant really do a full panel and let it dry on right?
im only going to do section at a time over few days, dont want to make it a full day thing, i can just like do the hood wax it then do another section another day right
