Can you tell us how that worked out for you? I'm pretty sure I need new front rotors (they've been turned once already) and I was looking at getting some EBC slotted rotors and green pads. Your info re: how helpful slotted/drilled really are on a daily driver was informative. I don't care about looks, but I want to get better than stock.
I'll provide an update once I get everything mounted. I was planning to complete it this weekend but my local Mazda dealer did not have the caliper bracket to hub bolts and it takes them 1 week to order it. Oh and they want ~$15 a bolt (x4)! Can be found online for ~$4 each… I know I already regret my pad choice
Btw, I decided to go with cyro fronts to satisfy my own curiosity but plain rears b/c there are is no cyro option unless I send it to a 3rd party for post processing (kinda pointless shipping dead weight back and forth). Centric's catalog is a bit confusing but here are some points I've learned. The first 3 numbers identify the actual rotors series.
Don’t quote the material composition as the bible. Only internet truth.
120 = premium rotor which is made of 60% pure metal, 40% scrap (best bang for the buck and well reviewed online)
121 = non-coated cheapies which are about 30% pure metal, 70% scrap, typical of you find at an Autozone (junk, pony up for the 120)
125 = not sure of material distribution but they are identified as heavy duty or commercial use. I can safely assume this line has more pure metal and less scrap than the 120s as it cost more. I 'suspect' these are the blanks used for Power Slot and/or Stop Tech rotors. You cannot get Power Slot or Stop Tech blanks same as how you cannot get any Centics slotted or drilled.
126 = Power Slot series
128 = Stop Tech series
My speculation: Centric = plain and avail in cheap, medium, to expensive; Power slot = slotted Centric 125, and Stop Tech = drilled Centric 125. This makes sense as it allows them to position each product differently and my best guestimate based on the price difference. Cyro treatment is offered on the 120, 125, 126, and 128 but limited to the certain models and from what I can see, only front rotors.
I went with 125.45078CRY MS3 front and 120.45065 Mz5 rears (no cyro 125 option avail for Mz5 front or rear :'().
