Here's a detailed photo of the BNK8-66-4M2. The dark blue and grey sheathes (I believe) are the stock wiring for the pods on the steering wheel. The green sheath is for the paddle shifters, and the black is the horn connector.
This is how I believe everything will connect:
The small end of the green connector plugs into the sub harness attached to the paddles themselves (I know this, because I've plugged it in to check).
The larger connector the attaches to everything connects to the steering wheel harness going to the car.
The black connector plugs into (edit) the horn (\edit). Thanks SVShootingStar
The dark blue and grey wires plug into the steering wheel pods.
Most of these are assumptions I've made based on the information I could find, and the harnesses I have on hand. We'll see what's what when I open up the steering wheel.
Another shot with the paddles attached
Last Edit: I can confirm that the paddles I ordered did NOT come with the screws needed to attach them to the wheel. (Good thing I ordered that separately).
...sent...
