P5 Tire, Rim size question, please help
G_MAN75
I posted this up b4 , but i never had the offset measurement,
and i do now. I have a 16x7.5 rim with a 45mm offset. I was wondering what size of tire i should/have to get.
I know that the factory tire is probably not wide enough.
Also want to know how low i can go when i get some springs...
I'm thinking 2" spools might be to much so maybe eibachs 1.2 1.6 drop would be good.
need some input please
Thanks Tony :confused:
I'm not sure about this but I don't think a 45 offset will work for a 7.5 inch rim. You may need a 48 offset so you don't rub on the fender
if you do NOT drop it...you MIGHT get away with the +45 using a 205 width tire.....
but by far.....a +48 would be better.....if you want to go wider than a 205....say a 215.....a +48 or better offset will be REQUIRED.
