thrasher said:It will just pop off, no screws.
I believe there are 4 pins going into the dash, outer edges near the top & bottom.
If you take the glove-box out you can snake your arm inside and push the bottom pin to get you started. Much easier to use a small putty knife around the edge to get your fingers started, then just pull it, carefully, just like the door panels.
oh yea i forgot about the control cables.
good call
to answer leicas question 5x7s and 6x8s are interchangeable IIRC
