Super Unique
- 2008.5 Mazdaspeed 3 Black Mica
a bad purge valve will exhibit the following.
if you fill the gas tank, drive the car until it is empty again, stop , fill the car, now it will be very hard to start, and idle very poorly stalling etc.. for about 10 - 15 seconds then run normal again. also all the time with the bad purge valve it will always feel just a bit "off" in that the idle is just not quite right, some hesitation that comes and goes. I can definitely feel the difference now that mine is fixed. it is just so much smoother than before, and a silky smooth idle now compared to then.
