system too lean at ldle.. i chekced every vacuum hose and recir hose, seems no leak at all, sometime my rpm is bouncing around when its cold,and when i back in neutral during higher speed my rpm stays at around 1200,it will drop to normal rmp when car is stop. also i check the o2 sensor, it looks fine just kinda dirty(maybe cause my cattless dp), plus i only hold 15psi(should be more like 17psi with cattless dp/rp?). what could it be wrong??? someone with knowledge please help this bro out!!im really have no clue whats going wrong. my mods r BOV,INTAKE,INLET,CATTLESS DP/RP. any help will be greatly appracited!!!!
