p0455 code, and need an explanation of the evap system and one way valves
brant914
I keep throwing a p0455 code, for large evap leak
on my 1997 1.5 with 130K
of course I replaced the gas cap, but that wasn't it
the leak is larger
intelli fix, is recommending the canister drain cut valve....
I've pulled the fender liner a couple of times and inspected all of the lines and connections
I've also lightly pressurized the gas tank (7-8 psi) and sprayed soapy water on all of the lines and connections
none of the connections are leaking
some of the 1 way valves show soap bubbles
I'm not certain though of the working steps of the 3 different one way valves and two different electrical connections in the system
I realize it could actually be a failed pressure sensor with no leak really existing....
does anyone have a laymans explanation (pictures?) of the evap system in the back of the car/tank.
I will then need to next move to the front/engine bay part of the system also
but so far nothing visually stands out.
any help appreciated
thanks in advance everyone!
brant
