P0421 on 2002 626
CrazyTasty07
I'm getting a P0421 on my 02 626. I've been trying to get an emissions test done and can't seem to get this code cleared. When I originally had the test done, I was getting a P0300 and the P0421, however, I've since had the plugs & wires changed, and replaced the O2 sensors. The P0300 is gone, however, the check engine light has come back on and I'm still getting the P0421. I have no knowledge of car repair at all, but I was wondering if anyone might have any ideas as to what else we can try fixing?
What do they do for an emissions test? Is it an OBDII scan or an actual tailpipe test? The P0421 is a catalyst efficency code and most likely the cat will need to be replaced. Its failure may be the result of the misfiring that you have already repaired. Is it a 4cyl or V-6?
