Overhead Light door switch.
SeCX-9
2016 Mazda CX-9 Signature
I noticed tonight that my overhead courtesy lights didn't go on when either front door was opened. The lights on the lower inside door panel do work however. The lights overhead work fine when switched to manual on. I haven't poked around yet, but can anyone point me to where the door switch might be located? Any other possible sources of the problem perhaps?
Thanks
may sound silly but do you have the overhead switch in the middle position? to the left is all lights off - the middle is for lights to go on with doors open and when set to the right all lights go on. worth a shot - Also, if it is in the middle and the doors are open and the lights are off, then press both buttons to turn on lights and that should fix it.
