Ordered the Hybrid BOV from Turboxs!
MS3TR
Talked with Jermaine from Turboxs about this BOV yesterday (http://www.turboxs.com/item.php?ID=243) and had to order it. He confirmed that this runs in Rec. mode and VTA and has been tuned to do so correctly on this engine. This was made specifically for MS3 so its a direct bolt on without any additional hardware needed.
He said it sounds awesome! I"ll post pics and maybe a video after I put it on. It should be here friday. He also said this car is a beast and it responds to mods very well. With a downpipe,test pipe, CAI, BOV, they have seen 290 HP and around 320 pds of TQ and this is without touching the boost!
2007 MazdaSpeed 3 - True Red
RIP: 2003 350z
i must say i dont recomend it. it may be "tuned" to work, and i'm sure it will.
but you are still venting air that has gone through the MAF, this is never a good idea. although my car ran 100% fine with my greddy type s running VTA, i did lose some fuel mileage, but that is it. i just wanted to see how it would run and sound. all in all you WILL be running a little rich between gear changes and WILL shorten the life of you cat, and spark plugs. i woud say if you just want whoosh, whoosh noises and want the car to run like it should.... keep the stock BOV and buy a CAI... it will make noise !
