I recently was changing all my vacuum lines to silicone and noticed oil in the lines I took off from the PCV valve to the intake manifold. I did some reading up on the subject and concluded since I recently upgraded my SMIC causing my boost to go up a couple psi's, that I needed to upgrade my PCV valve. From what I've read our stock PCV valve was only meant for stock boost and starts to leak once the boost is turned up which would explain the oil in my vacuum lines. I just ordered the Millenia PCV valve and was wondering if those of you that have upgraded to this in your cars, is a oil catch can still necessary and/or suggested? I bought one but am having trouble finding room to mount it so I was thinking if it wasn't necessary or suggested then I would use it as a coolant catch can as I have seen others on here do. Any help or advice is appreciated.
