only mid-pipe?
MicaSp33d
Mazda, Mazdaspeed3, 2008
will the aftermarket mid-pipes out right now be a direct bolt-on for our stock dp and cb.
If it is .. will i see any gains from just a mid-pipe?
Yes an YES. If you use the household brands. am I right fellas? Down pipe makes more performance available. But you should keep a high flow cat in there somewhere for inspection
