I just replaced my front motor mount which was completely shot, but as I suspected it was not the only noise I have in the front end. The swaybar end links are also clunking, but to my surprise the swaybar bushings seem to be okay. The stock bar seems to measure 21.5mm, but I don't see a lot of gap or play in the bushings. On my other cars I usually wear the bushings before the end links.
Has anyone used Energy Suspension bushings (or any other brand) on their stock bar? If so, what was the brand/size you used?
Do most of you find it's just the end links that go, and the main bushings are okay?
Are AWR end links the only option aside from factory units?
Thanks for any help.
- JP.
- JP.
