Struts are definitely going out, I did the bounce test and the passenger side made a loud howl and the driver made a squeak plus it's Alittle bouncy over bumps, which is kinda obvious. I should be able to replace them in the next couple of weeks. And I'm going to replace the swaybar bushings with poly bushings but I ended up buying the wrong size I guess. If anyone knows the stock lx swaybar size I'd definitely appreciate it. 23mm is big almost a 1/8th inch all the way around it
Sent from my 0PM92 using Tapatalk
