Laser03pro
- 1995 Miata
Dont only special places carry amsoil like redline and royal purple.
flyguy said:Hello all:
Hope no one minds me posting here while I wait for my approved vendor status to be finalized. I am an Amsoil dealer and would like to particpate in this discussion about oils and what makes them good or bad.
Flyguy
Your post is confusing... but amsoil, redline, and royal purple are all oils. But yes typically only special places/racing stores typically will carry the products. Amsoil can be found though with some good motorcycle shops I believe as it's used a lot for those poor engines.Laser03pro said:Dont only special places carry amsoil like redline and royal purple.
TurfBurn said:Please do post!!! Amsoil dealer online is music to my ears!!You just have to convince me (just pm me) to use your gear oil instead of Redline. Otherwise you guys are definitely my A-Lister.
I believe that as long as you aren't "selling" anything in your posts you are very much allowed to post info.
thumpr said:so viscosity ratings for synth oil is the same as petro oil. i've always wondered this, if maybe you know 10w30 meant the same thing, same temperature sensitivity for both kinds.
TurfBurn said:So what about turboed applications. A protege I believe recommends a 5w30... but what should a turboed car use? If I go from NA to running 10 psi daily??
flyguy said:A turbo'd car is not necessarily that much harder on the oil than nonturbo but it certainly has the potential to burn up the oil. Personally, I don't think anybody here, from the sounds of it most are quite knowledgeable, would abuse the engine by running it hot and hard and then just shutting it off and walking away without at least some cool down. Amsoil's recommendation for nonturbo is somewhere between 5 to 7 times longer than the manufacturers and for turbo it is 2 to 3 times longer.
You will do your oil and your engine a lot of good by warming it up easily and cooling it down gently.
flyguy
TurfBurn said:Is there any reason to run a heavier weight then in a turbo car? It seems to be that more or less everyone does go ahead and run a fair bit heavier weight oil as soon as they go turbo.
Personally I like to run as much boost as possible from the moment the key turns on to the moment it goes off...Kidding!!!!!
RyanJayG said:flyguy, I've heard of people never changing a synth oil. from what I've been told, it doesn't ever really break down, so all they do is change the filter and drain/add a quart. is this fallacy or truth?
