an easier way and the only way i know of,is to get the conversion kit for a spin on filter and then get the prosport sandwich plate.
At one point Ken told me that that Prosport plate will not fit the MS3? I had one on order along with the conversion kit and he recommended I cancel the order until Prosport revised the plate's fitment.
What gives?
Instead of an oil pressure gauge, you may want to consider checking the oil level on a regular basis.
...I'd also be curious to know of a good method of checking the dip-stick while traveling at high speeds, esp while accelerating, when oil pressure is of the most interestInstead of an oil pressure gauge, you may want to consider checking the oil level on a regular basis.
Nah, it's not too big a deal. Sometimes the fittings for the gauge can be a pain -- I had trouble with them on my last car because I'm a newbI read about the fitment problem as well. Putting an adapter on for the oil filter is a bit scary anyway, IMO.
Converting the oil filter allows the use of other filters besides Mazda's OE part, which is a benefit in and of itself. Also, to some, having a custom fitting made is at least as difficult as screwing together some plates and fittings.you dont need to convert the oil filter all you have to do is take out the stock oil presser sencer off put in a T fitting now all three sides are going to have diffrent threds you will ( i did) have to have one custom made but it dose work i have the prosport oil press in my car no biggy
