s***!! (spank)twilightprotege said:brian....wrong piccy....but a nice piccy anyway![]()
I would stick the temp sensor in the block and take the sensor that was in the second hole and put it on the T. There are seemingly two pressure sensors on teh 3rd gen. The temp sensor has to have flow, the pressure sesor can be pretty much anywhere as long as the seal is good!mcstark said:Hey Brian...so from reading this it's possible to install both an oil pressure and temperature gauges in a P5? I understand using a t-fitting for the pressure because you don't want the idiot light on, but would I need to use one for the temp gauge -- seeing as it doesn't lead to anything? Or would it be a good idea to use a t-fitting there to...just in case it's used for diagnostics?
Thanks!
I'm really not familiar with the manual type, however, there is alot of pressure running in the block to feed the guage, so choose your line well. Also after reading the thread, are there any questions you need cleared up?russwess said:I got a mechanical autometer sport-comp guage, and I was wondering if it is possible to mount it into the cab of my mp5? Also, has anyone done this install if it is possible, and finally, Can you give me an idea about how you installed it ? like did you run 1 line or 2 lines to it, b/c of it having to have flow.
thanks
twilightprotege said:electrical guages are just as accurate. they have a pressure sensor at the engine and just send a signal to the guage. no different from havnig the sensor at the guage
HAHAHA!! Thats the biggest joke I/ve ever heard! AutoMeter gauges 100% Accurate!?!?russwess said:Is it not a good idea to install mechanical guages inside of a car? I am curious b/c I bought the guages for the simple fact that they are 100% accurate. any suggestions also??? thanks for your input on these issues.
They might not be 100%, but they are better than running a light. I'm sure that people have done it before. All you need to do is tap the block in the rear by the firewall by removing the stock oil pressure sensor. Unplug it and leave the wire alone. You will loose the idiot light for ever.russwess said:Is it not a good idea to install mechanical guages inside of a car? I am curious b/c I bought the guages for the simple fact that they are 100% accurate. any suggestions also??? thanks for your input on these issues.
