So after about 1000 miles on the new engine, I checked the oil and found that there was a noticable bit of oil missing. I looked underneath and found that there is a small oil leak. i jacked the car up and found where I think the leak is coming from. It looked like the oil was coming from one of the bolts on the bracket that held the passengers side cv axle to the block. Is that possible, as I did not know that the bolt holes webt anywhere near the inside of the block? So is there any possible way that oil is leaking from the axle bracket, or should i be looking higher around the fuel filter and sandwich plate?
