You guys ever watch horse power TV? they have a new engine dyno, so they tried it out, ran with regular oil, then switched to Royal Purple, same engine, same parts, same temps and everything, it made a extra 8 hp and 7fp-tq. I also see trucks do the same thing, the truck made a extra 3wph and 2 fp-tq (at the wheels).
I've never heard of redline, but I assume it's much the same.
royal purple is different from most synthetic motor oils because it uses a high concentration of microscopic calcium particles that fill in the gaps so to speak in the cylinder wall which provides better piston ring sealing and compression and therefor increases the HP of the engine. There are downsides to this high concentration however, namely, if used for extended service periods the metal particles can acutaly start to accumulate in the oil galley passages which eventualy leads to restricted flow/clogged passageways.
so if you must use royal purple, even though it's marketed twoard exteneded services periods, I would suggest nothing longer than 5K, or mabye even less.
