BlitzxCraig
- Mazda Proteg5
Hello all,
I have a 2002 Protege5 and I just changed the oil for the first time since I've owned it. The previous owner changed it with full synthetic about 4000 miles ago, and I went back to conventional oil for this change. Anyway, I read that oil capacity with filter change is 3.7 quarts. I used mobil1 super high mileage and a fram oil filter. When I went to put the oil back in it, I put just a little over the 3 qt line then checked to see the dipstick level, and it seemed to be overfilled, to the point where it was on the round rod part of the dipstick. I made sure to drain the oil pan to the point where it was no longer dripping, and I changed the oil filter. I chalked it up to the oil not draining down yet and called it a night. This morning, I checked it again and it still seems to be overfilled. Any comments on how this could happen? This is not the first time I've changed oil, but it is the first time I've had a problem with something like this.
Thanks in advance.
Thanks in advance.
