Oil capacity for Mazdaspeed3?
blynzoo
Contributor
'02 Red P5...BUT AS OF 1/31/08 an '08 Silver SPEED3!!!
Quick question, guys. My owner's manual was stolen when the car was broken into a while back. I am doing the spin-on filter conversion today, and just realized I cant remember how much oil I add. How much do i need to add?
Simple question, hope someone can throw me a response quickly. This is motivation to get my ass to the dealership for a replacement.
Thanks!!!!!!
first off you're kinda posting in the wrong section, and secondly it's somewhere around 6qts. when i do my oil change i usually end up putting in just under 6 qts. but you can definitly dump in a whole 5qt oil jug, then take a 1qt and just do dip stick checks while pouring so as not to overfill
Mine was 5 1/2 quarts before the spin-on. Now with a truck-sized (B3000) filter, it's 6 1/2 quarts. That's a K&N HP 2009. The smaller filter is HP 1002. That would probably be in the six-quart range.
You can probably download a manual.
Thanks everyone, I used the B3000 filter, and did six. I'm going to let it settle and dip it tomorrow. Oakland and Mike, you guys are the tops. Thanks, homies. :)
Just an FYI- no need to let it settle overnight. Any time you change the oil, add a little bit less than you think it needs (like 1/2 quart less), fire up the engine for 30 seconds to get oil into the new filter, then let it settle for 1-2 minutes before checking. And remember- to check properly, pull the dipstick, wipe it clean, then dip it again to do the actual level check. And of course, check it with the car down on the pavement, and level. Top off as needed.
Just an FYI-remember- to check properly, pull the dipstick, wipe it clean, then dip it again to do the actual level check. And of course, check it with the car down on the pavement, and level. Top off as needed.
YES YES
Dunno why, this car is weird, but, if you let it sit , cool, calm, and collected and pull the stick for a read..... mine will show just under the add mark. shove back in and pull it quick, reads normal.
never seen that before and I dunno how it could even happen.
metal stick---puddle of oil---gravity
YES YES
My 3i did this too...scared the sh*t out of me the first time I saw it. Every other car I've owned, I just pull it after it's sat overnight and got an accurate reading.
I don't even bother looking at the dipstick on the MS6 on the first pull anymore. It barely reaches the 'add' mark.
I've contemplated what could possibly cause this. My only conclusion is some sort of trapped air bubble, but I don't know how even that would be possible.
It's simple physics:
Cover the end of a straw with your finger and dip it in a glass of water.
Notice that the straw does not fill up with water until you remove your finger from the end of it.
I wonder how many people are not taking this into account when checking their oil.
Dipsticks arent hollow
Um, yeah, lots of them are, in fact, most I've seen inside various engines I've worked are a plain tube, straight into the pan. A good effort at trying to get out of admitting you're wrong, though. (wink)
Is the MS3 a hollow tube read from the inside??
Your attempt to invoke the principal of capillary action
and apply it to the outside of the capillary tube, when the tube does not even exist.?!
Wow, the Wizard of OZ would be impressed
No, but the tube that the dipstick is inserted into IS hollow.
Since you still couldn't figure it out:
The dipstick tube is analogous to the straw.
The end of the dipstick is analogous to the finger on the end of the straw.
Notice the o-ring (which forms an air seal) near the end of the dipstick.
If there wasn't an o-ring (air seal) near the end of the dipstick, this "oil level discrepancy" wouldn't happen.
All you have to do is lift the dipstick up a couple of inches, which allows some air to escape (and the oil level to rise in the tube).
The dipstick does not reach into the oil pan.
Ain't physics cool?
Ain't physics cool?
now this, is a possible avenue.
if the dipstick tube were longer than the stick
and reached below the level in the sump
the seal on the stick( there is one) could create a situation with a different pressure than atmospheric. which is what the sump sees
NOW
after say 1 minute post shutdown 99 -44/100's of the oil has returned to the sump, sump level all lagoon quiet.
WHAT would at that time, raise the pressure in the dipstick tube, and hold it over nite so that the level in the tube is depressed about an inch. I jerk the stick out, and see this artificial level
I am fluent in Torr, Cwp, mmHg, psi, and bar.......... but I cannot give a conversion number for inches of oil But my WAG would be 0.5 to 2 psi to create the difference, not much
Changed out the oil and filter last night with my spin-on. It took about 5 3/4 quarts and it reads right at the full mark. I'm using the regular-sized filter.
hmm, does a spin on conversion make for a mazda NA warranty invalidation, should they feel the need?
