mishkakrisa
- mazda protege 5
Hey Guys!
New to the forum and am admittedly a total noob when it comes to doing maintenance. (Tired of paying through the nose for maintenance.) So, be patient if you can...I'm going to ask some pretty obvious questions..well, not obvious to me ;-)
I'm doing an oil change and ATF change on my '02 protege5(Yellow) I was reading a how to about changing the transmission fluid and am a bit confused.
If you add tranmission fluid through the ATF dipstick, it should go to the transmission, right? Is is possible for it to get into the oil pan? Because i think that may be where it's going. I've looked at the manual and i've looked through the forum and i honestly cant find pictures of the ATF plug on a protege 5 vs. the oil plug on a protege 5.
I appreciate some people are going to advise me to have a pro do it, but I really want to learn to do this myself.
Also, I'm a bit confused about what weight of oil I should get. There seems to be a lot of conflicting opinions...synthetic, etc.. 3.7 quarts vs. 4.
Anyway, if you could help a guy out..I'd really appreciate it.
All the best
Mish
All the best
Mish
