This is coming from my knowledge of emissions on my P5, which uses two catalytics. You probably did one of the following:
1. Forgot to reinstall 2nd o2 sensor or busted it.
OR
2. You didn't do any modifications to the 2nd o2 sensor. In my p5, the 2nd o2 sensor checks to make sure the emissions system is working properly. When I put my header on (removing the 1st cat), I had to modify the 2nd o2 sensor using two spark plug non-foulers which brought the sensor out of the exhaust stream. The other option was the MIL eliminator fix which involved rewiring.
Check around and see if #2 is required for your car's mod. I'm betting it is.
hey brother,
could u pls tell me more in detail about the mods to the second o2 sensor. im not quite sure by what u mean on how to mod it?
thnx
