Off to the dyno :)
Davidb
Today a local shop is having a dyno day. I don't think they will have a/f readings available today. It is a dynojet dyno. Today the temps should be in the lower 40's and humidity should be around 70%.
My mods are cobb intake and 17psi. guess my numbers, i'll post them up when I get back :)
245hp and 275tq on 18 psi dropping to 15-16psi at 6000rpm.
run was in 4th gear. one big fan in front of the car with hood up. other two runs were breaking up due to the dyno itself.
the dyno should be emailed to me in a few days so i'll post it up then. The one fan thing really sucked. The intercooler was hot to the touch...I mean really hot after my first run so they were all lower.
other things that dynoed...
99 c5 bone stock 305hp 330tq
06 viper stock 410hp 440tq
01 s2k test pipe 197hp 130tq
scyclone truck Not stock 515hp 525tq
08 shelby gt stock 265hp 273tq
I didn't stay very long...
no boost leaks. everything is good there. im still running 11.0 in 1000ft at 96 with thoes mods.
a dyno is a tuning tool and there are so many different varibles...
what elevation did the dyno use in its setup? all those results sound a little low (for the other cars as well(
the truck was converted to rwd for the dyno...ill get some specs on it and I will get a pic of it.
I dont know how the dyno was set up...all those numbers were corrected numbers and some did seem low.
if you post a sheet i will move this to the dyno subforum so please post one up so its there for people to look/drool over...
thanks
