slowmotionmsp
- Titanium 2003.5 MSP
How can i tell if my OEM motor mounts are no good anymore?
Can anyone tell me, please!? Thanks!
If your shifter moves a lot when accelerating or decelerating, you have a worn out mount.slowmotionmsp said:How can i tell if my OEM motor mounts are no good anymore?
Fede_italiano said:If your shifter moves a lot when accelerating or decelerating, you have a worn out mount.
Thant is how my dealeship replaced mine.
I believe it replaced fron in warranty and toke a couple of days.slowmotionmsp said:Thanks Fede_italiano!
Did your dealer replace all the front, rear and side motor mounts under warranty? If, so, how long did they take?
My shifter isn't moving alot, but, someone who knows about tuning cars was taking a look at my engine today and said when i rev it, it has 2 to 3 inch movement which is too much and the mounts are damaged.
I was wondering if there was anyway to tell without taking the mounts of the car to see if they were damaged?
Fede_italiano said:I believe it replaced fron in warranty and toke a couple of days.
After that the shifter moved a lot less.
Remember that the stock mount are soft but 2 - 3 is definitively not normal operation.
I meant 2-3 inches of movement is not normal.slowmotionmsp said:What's that about the stock mount's being soft "but 2 - 3 definately not normal operation"?
Sorry, can't follow what you said there. Thanks
Also, like i said, my shifter is fine, but, i just want this thing fixed before my warranty runs out in this month probably. I have almost 50k on my car now. I was concerned if the mounts eventully go bad, i might as well try to find out if they are bad now, and i guess the only way they can tell is by taking the mounts off the car?
Rac3rX said:YOu can see the front and side mounts by opening the hood and looking at them.
You can also tell from excessive wheel hop & Engine lash during shifts or on/off throttle.
Even if the mounts are replaced under warently they are replaced withthe same garbage thhat was there originally.
Replace your mounts or get incerts with aftermarket parts & your all set.
I can see my side mounts ripped. My rear was torn to s***.
I got incerts put in, and all is well.
How long have you had the car?
Fede_italiano said:I meant 2-3 inches of movement is not normal.
Rac3rX said:DONT listen to the Stealership they told you a bunch of BULL s***, Im sure many will agree.
1st Thing a sway bar wont do s*** for wheel hop, what kind of a moron is that jack ass? 2nd the movement is ONLY normal for a motor with JUNK mounts. 3rd You have wheel hop, you have mount issues (Hell ALL 3rd Gen Proteges Have motor mount issues, simple as that)
AND the ******* moron knows s***, because 100% stiffer motor mounts STOP wheel hop, and week ass motor mounts CAUSE wheel hop, from the motor jerking arround like a ******* bucking hourse. I would go back there ans SLAP THE s*** OUT OF THAT ASS HOLE!!!!!!!!!!!!!
Incets from RR-racing $55 shipped, are here (They only make front and rear)
http://www.rr-racing.com/engine-mounts.htm#Current Inventory
AWR makes full mount replacements AND Incerts.
http://www.awrracing.com/store/product_info.php?products_id=251
They dont make a Front incerts, so the best incert combo would be a pair of Side mount incerts fromAWR, coupled with Front & rear incerts from RR-racing
Rac3rX said:"stiffer mounts will not reduce wheel hope but you need a stronger sway bar"
The Guy at the Stealership who said this REALLY NEEDS A ******* b**** SLAP!!! He should never touch a car again, LIFETIME BAN FOR UTTER STUPIDITY!!!!!!
slowmotionmsp said:I showed the car to the service people at the dealership (stealership!) and they have called me in to leave my car with them on wednesday. They saw the mounts and i also showed them my turbo had oil around it. they said they will look at both these issues and let me know what it is they can do under warrenty.
by the way, i ordered the front and rear rr racing mount inserts already, can't wait to get them in!!
Thanks again for the time you took to respond back!
P.S., i hope they give me a new turbo! lol
