Odyssey PC680
Vitt
Has anyone used this battery in the MZ3? I was thinking to get this as a replacement since it's a lot lighter. I think it should crank the 2.3 liter engine and should last if I take care of it. If so do you need a different battery tie down? TIA
PC 680 Specs:
680 cranking amps for 5 seconds
595 cranking amps for 10 seconds
525 cranking amps for 20 seconds
17 amp hours
Short circuit current over 1800A
25 minute reserve capacity with 25amp load
Female brass terminal w/M6 SS bolt
Length 7 1/16"
Width 3"
Height 6 9/16"
Weighs less than 15 lbs
