its for T3 turbo if i am correct...(suggest u get Steedspeed T3 or group buys manifolds from this forum when theres one.)
if you just want a cheap one to replace the old rusty cast iron
you might need to type in more info to get the mass production cheap T2/T25 turbo manifold. (which i just brought, reinforced and installed)
hint "select the search price range to 190 -220 you should find it with ease"
I mostly just wanted to see if anyone has ever tried one out.
i'm almost 100% sure the one pg sells is the same one on ebay for $200. which is a thunder copy
