Lost Momentum
2025 Mazda CX-5 GT SP 2.5L Turbo AWD
- 2012 Mazda CX-5 GT 2.2L Diesel AWD (Gone but not forgotten)
With the advent of modern technology and very cheap electronics & apps, what monitoring apps are you using and what do you like to look at. I don't monitor the car all the time, I just use it every now and then just to check 'whats going on'
I have the Forscan app using a mobile phone to read all the data. Dashboard is as follows:
Battery Voltage
Engine Coolant Temperature
Engine Oil Pressure
Engine Oil Temperature
Distance traveled since last oil change
Total number of DPF Regens
Amount of Particulate Matter generated (g/L)
Distance traveled since last DPF regen
DPF Regen ON/OFF
Exhaust Gas Temperature
Gear Position
Rear Differential Temperature
Transmission Oil Temperature
Torque
All a bit of cheap fun that one day could save you thousands of $$$$
Battery Voltage
Engine Oil Pressure
DPF Regen ON/OFF
Gear Position
Torque
