I thought i would post up a list of generic OBD II codes, not sure if someone has done this already but may be we can add this to the stickies somewhere.
P0001-P0099 - Fuel and Air Metering and Auxiliary Emission Controls
- P0001 Fuel Volume Regulator Control Circuit/Open
- P0002 Fuel Volume Regulator Control Circuit Range/Performance
- P0003 Fuel Volume Regulator Control Circuit Low
- P0004 Fuel Volume Regulator Control Circuit High
- P0005 Fuel Shutoff Valve "A" Control Circuit/Open
- P0006 Fuel Shutoff Valve "A" Control Circuit Low
- P0007 Fuel Shutoff Valve "A" Control Circuit High
- P0008 Engine Positions System Performance Bank 1
- P0009 Engine Position System Performance Bank 2
- P0010 "A" Camshaft Position Actuator Circuit (Bank 1)
- P0011 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
- P0012 "A" Camshaft Position - Timing Over-Retarded (Bank 1)
- P0013 "B" Camshaft Position - Actuator Circuit (Bank 1)
- P0014 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1) - See Trouble Code P0011
- P0015 "B" Camshaft Position -Timing Over-Retarded (Bank 1) - See Trouble Code P0012
- P0016 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A)
- P0017 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor B)
- P0018 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor A)
- P0019 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor B)
- P0020 "A" Camshaft Position Actuator Circuit (Bank 2)
- P0021 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
- P0022 "A" Camshaft Position - Timing Over-Retarded (Bank 2)
- P0023 "B" Camshaft Position - Actuator Circuit (Bank 2) - See Trouble Code P0020
- P0024 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2) - See Trouble Code P0021
- P0025 "B" Camshaft Position - Timing Over-Retarded (Bank 2) - See Trouble Code P0022
- P0026 Intake Valve Control Solenoid Circuit Range/Performance Bank 1
- P0027 Exhaust Valve Control solenoid Circuit Range/Performance Bank 1
- P0028 Intake valve Control Solenoid Circuit Range/Performance Bank 2
- P0029 Exhaust Valve Control Solenoid Circuit Range/Performance Bank 2
- P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
- P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
- P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
- P0033 Turbo Charger Bypass Valve Control Circuit
- P0034 Turbo Charger Bypass Valve Control Circuit Low
- P0035 Turbo Charger Bypass Valve Control Circuit High
- P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
- P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
- P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
- P0039 Turbo/Super Charger Bypass Valve Control Circuit Range/Performance
- P0040 Upstream Oxygen Sensors Swapped From Bank To Bank
- P0041 Downstream Oxygen Sensors Swapped From Bank To Bank
- P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
- P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
- P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
- P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
- P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
- P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
- P0053 HO2S Heater Resistance (Bank 1, Sensor 1)
- P0054 HO2S Heater Resistance (Bank 1, Sensor 2)
- P0055 HO2S Heater Resistance (Bank 1, Sensor 3)
- P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
- P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
- P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
- P0059 HO2S Heater Resistance (Bank 2, Sensor 1)
- P0060 HO2S Heater Resistance (Bank 2, Sensor 2)
- P0061 HO2S Heater Resistance (Bank 2, Sensor 3)
- P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
- P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
- P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
- P0065 Air Assisted Injector Control Range/Performance
- P0066 Air Assisted Injector Control Circuit or Circuit Low
- P0067 Air Assisted Injector Control Circuit High
- P0068 MAP/MAF - Throttle Position Correlation
- P0069 Manifold Absolute Pressure - Barometric Pressure Correlation
- P0070 Ambient Air Temperature Sensor Circuit
- P0071 Ambient Air Temperature Sensor Range/Performance
- P0072 Ambient Air Temperature Sensor Circuit Low Input
- P0073 Ambient Air Temperature Sensor Circuit High Input
- P0074 Ambient Air Temperature Sensor Circuit Intermittent
- P0075 Intake Valve Control Solenoid Circuit (Bank 1)
- P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
- P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
- P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
- P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
- P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
- P0081 Intake valve Control Solenoid Circuit (Bank 2)
- P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
- P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
- P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
- P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
- P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2)
- P0087 Fuel Rail/System Pressure - Too Low
- P0088 Fuel Rail/System Pressure - Too High
- P0089 Fuel Pressure Regulator 1 Performance
- P0090 Fuel Pressure Regulator 1 Control Circuit
- P0091 Fuel Pressure Regulator 1 Control Circuit Low
- P0092 Fuel Pressure Regulator 1 Control Circuit High
- P0093 Fuel System Leak Detected - Large Leak
- P0094 Fuel System Leak Detected - Small Leak
- P0095 Intake Air Temperature Sensor 2 Circuit
- P0096 Intake Air Temperature Sensor 2 Circuit Range/Performance
- P0097 Intake Air Temperature Sensor 2 Circuit Low
- P0098 Intake Air Temperature Sensor 2 Circuit High
- P0099 Intake Air Temperature Sensor 2 Circuit Intermittent/Erratic
- P0100 Mass or Volume Air Flow Circuit Malfunction
- P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
- P0102 Mass or Volume Air Flow Circuit Low Input
- P0103 Mass or Volume Air Flow Circuit High Input
- P0104 Mass or Volume Air Flow Circuit Intermittent
- P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
- P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
- P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
- P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
- P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
- P0109 Intake Air Temperature Circuit Malfunction
- P0111 Intake Air Temperature Circuit Range/Performance Problem
- P0112 Intake Air Temperature Circuit Low Input
- P0113 Intake Air Temperature Circuit High Input
- P0114 Intake Air Temperature Circuit Intermittent
- P0115 Engine Coolant Temperature Circuit Malfunction
- P0116 Engine Coolant Temperature Circuit Range/Performance Problem
- P0117 Engine Coolant Temperature Circuit Low Input
- P0118 Engine Coolant Temperature Circuit High Input
- P0119 Engine Coolant Temperature Circuit Intermittent
- P0120 Throttle Position Sensor/Switch A Circuit Malfunction
- P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
- P0122 Throttle Position Sensor/Switch A Circuit Low Input
- P0123 Throttle Position Sensor/Switch A Circuit High Input
- P0124 Throttle Position Sensor/Switch A Circuit Intermittent
- P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
- P0126 Insufficient Coolant Temperature for Stable Operation
- P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
- P0130 02 Sensor Circuit Malfunction (Bank I Sensor 1)
- P0131 02 Sensor Circuit Low Voltage (Bank I Sensor I)
- P0132 02 Sensor Circuit High Voltage (Bank I Sensor 1)
- P0133 02 Sensor Circuit Slow Response (Bank 1 Sensor 1)
- P0134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
- P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
- P0136 02 Sensor Circuit Malfunction (Bank I Sensor 2)
- P0137 02 Sensor Circuit Low Voltage (Bank I Sensor 2)
- P0138 02 Sensor Circuit High Voltage (Bank I Sensor 2)
- P0139 02 Sensor Circuit Slow Response (Bank 1 Sensor 2)
- P0140 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
- P0141 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
- P0142 02 Sensor Circuit Malfunction (Bank I Sensor 3)
- P0143 02 Sensor Circuit Low Voltage (Bank I Sensor 3)
- P0144 02 Sensor Circuit High Voltage (Bank I Sensor 3)
- P0145 02 Sensor Circuit Slow Response (Bank 1 Sensor 3)
- P0146 02 Sensor Circuit No Activity Detected (Bank I Sensor 3)
- P0147 02 Sensor Heater Circuit Malfunction (Bank I Sensor 3)
- P0150 02 Sensor Circuit Malfunction (Bank 2 Sensor I)
- P0151 02 Sensor Circuit Low Voltage (Bank 2 Sensor I)
- P0152 02 Sensor Circuit High Voltage (Bank 2 Sensor 1)
- P0153 02 Sensor Circuit Slow Response (Bank 2 Sensor 1)
- P0154 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
- P0155 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
- P0156 02 Sensor Circuit Malfunction (Bank 2 Sensor 2)
- P0157 02 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
- P0158 02 Sensor Circuit High Voltage (Bank 2 Sensor 2)
- P0159 02 Sensor Circuit Slow Response (Bank 2 Sensor 2)
- P0160 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
- P0161 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
- P0162 02 Sensor Circuit Malfunction (Bank 2 Sensor 3)
- P0163 02 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
- P0164 02 Sensor Circuit High Voltage (Bank 2 Sensor 3)
- P0165 02 Sensor Circuit Slow Response (Bank 2 Sensor 3)
- P0166 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
- P0167 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
- P0170 Fuel Trim Malfunction (Bank 1)
- P0171 System too Lean (Bank 1)
- P0172 System too Rich (Bank 1)
- P0173 Fuel Trim Malfunction (Bank 2)
- P0174 System too Lean (Bank 2)
- P0175 System too Rich (Bank 2)
- P0176 Fuel Composition Sensor Circuit Malfunction
- P0177 Fuel Composition Sensor Circuit Range/Performance
- P0178 Fuel Composition Sensor Circuit Low Input
- P0179 Fuel Composition Sensor Circuit High Input
- P0180 Fuel Temperature Sensor A Circuit Malfunction
- P0181 Fuel Temperature Sensor A Circuit Range/Performance
- P0182 Fuel Temperature Sensor A Circuit Low Input
- P0183 Fuel Temperature Sensor A Circuit High Input
- P0184 Fuel Temperature Sensor A Circuit Intermittent
- P0185 Fuel Temperature Sensor B Circuit Malfunction
- P0186 Fuel Temperature Sensor B Circuit Range/Performance
- P0187 Fuel Temperature Sensor B Circuit Low Input
- P0188 Fuel Temperature Sensor B Circuit High Input
- P0189 Fuel Temperature Sensor B Circuit Intermittent
- P0190 Fuel Rail Pressure Sensor Circuit Malfunction
- P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
- P0192 Fuel Rail Pressure Sensor Circuit Low Input
- P0193 Fuel Rail Pressure Sensor Circuit High Input
- P0194 Fuel Rail Pressure Sensor Circuit Intermittent
- P0195 Engine Oil Temperature Sensor Malfunction
- P0196 Engine Oil Temperature Sensor Range/Performance
- P0197 Engine Oil Temperature Sensor Low
- P0198 Engine Oil Temperature Sensor High
- P0199 Engine Oil Temperature Sensor Intermittent
- P0200 Injector Circuit Malfunction
- P0201 Injector Circuit Malfunction - Cylinder 1
- P0202 Injector Circuit Malfunction - Cylinder 2
- P0203 Injector Circuit Malfunction - Cylinder 3
- P0204 Injector Circuit Malfunction - Cylinder 4
- P0205 Injector Circuit Malfunction - Cylinder 5
- P0206 Injector Circuit Malfunction - Cylinder 6
- P0207 Injector Circuit Malfunction - Cylinder 7
- P0208 Injector Circuit Malfunction - Cylinder 8
- P0209 Injector Circuit Malfunction - Cylinder 9
- P0210 Injector Circuit Malfunction - Cylinder 10
- P0211 Injector Circuit Malfunction - Cylinder 11
- P0212 Injector Circuit Malfunction - Cylinder 12
- P0213 Cold Start Injector 1 Malfunction
- P0214 Cold Start Injector 2 Malfunction
- P0215 Engine Shutoff Solenoid Malfunction
- P0216 Injection Timing Control Circuit Malfunction
- P0217 Engine Overtemp Condition
- P0218 Transmission Over Temperature Condition
- P0219 Engine Overspeed Condition
- P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
- P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
- P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
- P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input
- P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent
- P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction
- P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
- P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input
- P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input
- P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent
- P0230 Fuel Pump Primary Circuit Malfunction
- P0231 Fuel Pump Secondary Circuit Low
- P0232 Fuel Pump Secondary Circuit High
- P0233 Fuel Pump Secondary Circuit Intermittent
- P0234 Engine Overboost Condition
- P0235 Turbocharger Boost Sensor A Circuit Malfunction
- P0236 Turbocharger Boost Sensor A Circuit Range/Performance
- P0237 Turbocharger Boost Sensor A Circuit Low
- P0238 Turbocharger Boost Sensor A Circuit High
- P0239 Turbocharger Boost Sensor B Malfunction
- P0240 Turbocharger Boost Sensor B Circuit Range/Performance
- P0241 Turbocharger Boost Sensor B Circuit Low
- P0242 Turbocharger Boost Sensor B Circuit High
- P0243 Turbocharger Wastegate Solenoid A Malfunction
- P0244 Turbocharger Wastegate Solenoid A Range/Performance
- P0245 Turbocharger Wastegate Solenoid A Low
- P0246 Turbocharger Wastegate Solenoid A High
- P0247 Turbocharger Wastegate Solenoid B Malfunction
- P0248 Turbocharger Wastegate Solenoid B Range/Performance
- P0249 Turbocharger Wastegate Solenoid B Low
- P0250 Turbocharger Wastegate Solenoid B High
- P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
- P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
- P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
- P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
- P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
- P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
- P0257 Injection Pump Fuel Metering Control "B" Range/Performance Injector)
- P0258 Injection Pump Fuel Metering Control "B" Low (Cam/R
- P0259 Injection Pump Fuel Metering Control "B" High (Cam/R
- P0260 Injection Pump Fuel Metering Control "B" Intermittent Injector)
- P0261 Cylinder I Injector Circuit Low
- P0262 Cylinder I Injector Circuit High
- P0263 Cylinder I Contribution/Balance Fault
- P0264 Cylinder 2 Injector Circuit Low
- P0265 Cylinder 2 Injector Circuit High
- P0266 Cylinder 2 Contribution/Balance Fault
- P0267 Cylinder 3 Injector Circuit Low
- P0268 Cylinder 3 Injector Circuit High
- P0269 Cylinder 3 Contribution/Balance Fault
- P0270 Cylinder 4 Injector Circuit Low
- P0271 Cylinder 4 Injector Circuit High
- P0272 Cylinder 4 Contribution/Balance Fault
- P0273 Cylinder 5 Injector Circuit Low
- P0274 Cylinder 5 Injector Circuit High
- P0275 Cylinder S Contribution/Balance Fault
- P0276 Cylinder 6 Injector Circuit Low
- P0277 Cylinder 6 Injector Circuit High
- P0278 Cylinder 6 Contribution/Balance Fault
- P0279 Cylinder 7 Injector Circuit Low
- P0280 Cylinder 7 Injector Circuit High
- P0281 Cylinder 7 Contribution/Balance Fault
- P0282 Cylinder 8 Injector Circuit Low
- P0283 Cylinder 8 Injector Circuit High
- P0284 Cylinder 8 Contribution/Balance Fault
- P0285 Cylinder 9 Injector Circuit Low
- P0286 Cylinder 9 Injector Circuit High
- P0287 Cylinder 9 Contribution/Balance Fault
- P0288 Cylinder 10 Injector Circuit Low
- P0289 Cylinder 10 Injector Circuit High
- P0290 Cylinder 10 Contribution/Balance Fault
- P0291 Cylinder 11 Injector Circuit Low
- P0292 Cylinder 11 Injector Circuit High
- P0293 Cylinder 11 Contribution/Balance Fault
- P0294 Cylinder 12 Injector Circuit Low
- P0295 Cylinder 12 Injector Circuit High
- P0296 Cylinder 12 Contribution/Range Fault
- P0300 Random/Multiple Cylinder Misfire Detected
- P0301 Cylinder 1 Misfire Detected
- P0302 Cylinder 2 Misfire Detected
- P0303 Cylinder 3 Misfire Detected
- P0304 Cylinder 4 Misfire Detected
- P0305 Cylinder 5 Misfire Detected
- P0306 Cylinder 6 Misfire Detected
- P0307 Cylinder 7 Misfire Detected
- P0308 Cylinder 8 Misfire Detected
- P0309 Cylinder 9 Misfire Detected
- P0310 Cylinder 10 Misfire Detected
- P0311 Cylinder 11 Misfire Detected
- P0312 Cylinder 12 Misfire Detected
- P0313 Misfire Detected with Low Fuel
- P0314 Single Cylinder Misfire (Cylinder not Specified)
- P0315 Crankshaft Position System Variation Not Learned
- P0316 Misfire Detected On Startup (First 1000 Revolutions)
- P0317 Rough Road Hardware Not Present
- P0318 Rough Road Sensor A Signal Circuit
- P0319 Rough Road Sensor B Signal Circuit
- P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
- P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
- P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
- P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
- P0325 Knock Sensor 1 Circuit Malfunction (Bank I or Single Sensor)
- P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
- P0327 Knock Sensor 1 Circuit Low Input (Bank I or Single Sensor)
- P0328 Knock Sensor 1 Circuit High Input (Bank I or Single Sensor)
- P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
- P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
- P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
- P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
- P0333 Knock Sensor 2 Circuit High Input (Bank 2)
- P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
- P0335 Crankshaft Position Sensor A Circuit Malfunction
- P0336 Crankshaft Position Sensor A Circuit Range/Performance
- P0337 Crankshaft Position Sensor A Circuit Low Input
- P0338 Crankshaft Position Sensor A Circuit High Input
- P0339 Crankshaft Position Sensor A Circuit Intermittent
- P0340 Camshaft Position Sensor Circuit Malfunction
- P0341 Camshaft Position Sensor Circuit Range/Performance
- P0342 Camshaft Position Sensor Circuit Low Input
- P0343 Camshaft Position Sensor Circuit High Input
- P0344 Camshaft Position Sensor Circuit Intermittent
- P0345 Camshaft Position Sensor A Circuit Malfunction (Bank 2)
- P0346 Camshaft Position Sensor A Circuit Range/Performance (Bank 2)
- P0347 Camshaft Position Sensor A Circuit Low Input (Bank 2)
- P0348 Camshaft Position Sensor A Circuit High Input (Bank 2)
- P0349 Camshaft Position Sensor A Circuit Intermittent (Bank 2)
- P0350 Ignition Coil Primary/Secondary Circuit Malfunction
- P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
- P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
- P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
- P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
- P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
- P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
- P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
- P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
- P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
- P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
- P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
- P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
- P0370 Timing Reference High Resolution Signal A Malfunction
- P0371 Timing Reference High Resolution Signal A Too Many Pulses
- P0372 Timing Reference High Resolution Signal A Too Few Pulses
- P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
- P0374 Timing Reference High Resolution Signal A No Pulses
- P0375 Timing Reference High Resolution Signal B Malfunction
- P0376 Timing Reference High Resolution Signal B Too Many Pulses
- P0377 Timing Reference High Resolution Signal B Too Few Pulses
- P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
- P0379 Timing Reference High Resolution Signal B No Pulses
- P0380 Glow Plug/Heater Circuit "A" Malfunction
- P0381 Glow Plug/Heater Indicator Circuit Malfunction
- P0382 Exhaust Gas Recirculation Flow Malfunction
- P0385 Crankshaft Position Sensor B Circuit Malfunction
- P0386 Crankshaft Position Sensor B Circuit Range/Performance
- P0387 Crankshaft Position Sensor B Circuit Low Input
- P0388 Crankshaft Position Sensor B Circuit High Input
- P0389 Crankshaft Position Sensor B Circuit Intermittent
- P0400 Exhaust Gas Recirculation Flow Malfunction
- P0401 Exhaust Gas Recirculation Flow Insufficient Detected
- P0402 Exhaust Gas Recirculation Flow Excessive Detected
- P0403 Exhaust Gas Recirculation Circuit Malfunction
- P0404 Exhaust Gas Recirculation Circuit Range/Performance
- P0405 Exhaust Gas Recirculation Sensor A Circuit Low
- P0406 Exhaust Gas Recirculation Sensor A Circuit High
- P0407 Exhaust Gas Recirculation Sensor B Circuit Low
- P0408 Exhaust Gas Recirculation Sensor B Circuit High
- P0410 Secondary Air Injection System Malfunction
- P0411 Secondary Air Injection System Incorrect Flow Detected
- P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
- P0413 Secondary Air Injection System Switching Valve A Circuit Open
- P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
- P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
- P0416 Secondary Air Injection System Switching Valve B Circuit Open
- P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
- P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
- P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
- P0420 Catalyst System Efficiency Below Threshold (Bank 1)
- P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
- P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
- P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
- P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
- P0430 Catalyst System Efficiency Below Threshold (Bank 2)
- P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
- P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
- P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
- P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
- P0440 Evaporative Emission Control System Malfunction
- P0441 Evaporative Emission Control System Incorrect Purge Flow
- P0442 Evaporative Emission Control System Leak Detected (small leak)
- P0443 Evaporative Emission Control System Purge Control Valve Circuit
- P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
- P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
- P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
- P0447 Evaporative Emission Control System Vent Control Circuit Open
- P0448 Evaporative Emission Control System Vent Control Circuit Shorted
- P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
- P0450 Evaporative Emission Control System Pressure Sensor Malfunction
- P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
- P0452 Evaporative Emission Control System Pressure Sensor Low Input
- P0453 Evaporative Emission Control System Pressure Sensor High Input
- P0454 Evaporative Emission Control System Pressure Sensor Intermittent
- P0455 Evaporative Emission Control System Leak Detected (gross leak)
- P0456 Evaporative Emissions System Small Leak Detected
- P0457 Evaporative Emission Control System Leak Detected
- P0458 Evaporative Emission System Purge Control Valve Circuit Low
- P0459 Evaporative Emission System Purge Control Valve Circuit High
- P0460 Fuel Level Sensor Circuit Malfunction
- P0461 Fuel Level Sensor Circuit Range/Performance
- P0462 Fuel Level Sensor Circuit Low Input
- P0463 Fuel Level Sensor Circuit High Input
- P0464 Fuel Level Sensor Circuit Intermittent
- P0465 Purge Flow Sensor Circuit Malfunction
- P0466 Purge Flow Sensor Circuit Range/Performance
- P0467 Purge Flow Sensor Circuit Low Input
- P0468 Purge Flow Sensor Circuit High Input
- P0469 Purge Flow Sensor Circuit Intermittent
- P0470 Exhaust Pressure Sensor Malfunction
- P0471 Exhaust Pressure Sensor Range/Performance
- P0472 Exhaust Pressure Sensor Low
- P0473 Exhaust Pressure Sensor High
- P0474 Exhaust Pressure Sensor Intermittent
- P0475 Exhaust Pressure Control Valve Malfunction
- P0476 Exhaust Pressure Control Valve Range/Performance
- P0477 Exhaust Pressure Control Valve Low
- P0478 Exhaust Pressure Control Valve High
- P0479 Exhaust Pressure Control Valve Intermittent
- P0480 Cooling Fan I Control Circuit Malfunction
- P0481 Cooling Fan 2 Control Circuit Malfunction
- P0482 Cooling Fan 3 Control Circuit Malfunction
- P0483 Cooling Fan Rationality Check Malfunction
- P0484 Cooling Fan Circuit Over Current
- P0485 Cooling Fan Power/Ground Circuit Malfunction
