Good Day
Own a 08 MS3 with 59K on the odomater!
Anyone that has had a o2 sensor fail could you please describe the symptoms , have a P2177 coed.
Thank You
Thank You ordered a new one sholud be in Tuesday, $185.
Hope he didn't order the second one back from the engine. It will not work up front.
That's kinda why I was asking the question.
Where did you get the #1 O2 sensor for $185? They are usually around $375.
Thanks.
How? I just got mine from Mazda for $131!
That is the rear sensor also known as the narrowband. The wideband o2 is desno part number 234-5013. This sensor is located right in the engine bay against the firewall. The one for $130, is located underneath the car after the first cat. These two different o2 sensors are not interchangeable.
Thanks.
Russ Darrow Mazda! They have treated me pretty well except the $21 to patch a nail hole!
It is the pre cat #1 O2 wideband sensor.
