now boosted!!
joka1
Contributor
2002 Black Mica ES-T
well finally i am boosted but i can't boost more than a psi or 2 since my engine mangement isn't installed and working! besides that it is really hard to stay at 2 psi since all i want to do is press the gas more and more. (upyours) i cant wait to see how it feels when i can really boost! i will post pics when i get home from work tonight!
rob
1psi or 2psi? does that really count as being boosted?
j/k .. congrats man, and have fun on the dark side.. wish i was there with ya!
mpi kit off micah's car. i will be boosting 8 by this weekend once i figure out what is wrong with my mpi tuner. 1-2 is enough to know it works for now, i dont feel like blowing my engine!
Did you check over all the wiring? B/c a losse connection..or wrong wiring..will not permit the unit to work properly..talk to nick..i am sure he will be more than able to help you out!
Congrats on finally getting it install..do not go heavy on the gas..especailly with you not having the mpi unit setup properly!
G/Luck
Chas
i checksed the wiring like 4 times, everything was hooked up and soldered exactly like the directions said. but my car would not start and my laptop would not connect to the piggyback. so i dunno.. i will talk to nick probally tomorrow for his help!
rob
as promised here are some pics!!
all i have to do now is get rid of the red connecters and replace them with black!!
here is a pic of the full 3" exhaust with no cats
and here is the wired in piggyback that didnt work but i will get to work soon
agreed glossy black would look the best. also those IC pipes seem to be hanging a little low. could be the angle of the pic though..
they are low...... i will have to reweld the bends closer because they sit like 3 in off the road..... or just raise my car up some since it is all the way down on my coilovers!!
looking good!!! boosted is better!
Quick question....are the IC piping a concern? they look rather "low" from the pictures (it may not be the case "in person). will they hit the ground going over speed bumps or while doing some "spirited driving" around town?
plus abt the paint, that was just temp, it will change soon i just wanted to get it on there!! i dont know if the pipes are gonna stay a diffrent shade of blue or get turned to black yet!!!! now all i want is to get it tuned and running right...... damit i have to call mpnick tomorrow!!
2 things joka..
1. your intercooler piping is way to ******* low! You need to get that fixed before..you run over something!
2. the wiring for your o2 sensor is right over your turbo..that's bad...you need to cut them..and rewire it! Otherwise it will just melt the wires due to the extrememe temps of the turbo..
Chas
