My stock shocks blew out at 35,000 miles and I upgraded to Koni FSD's (4040s). I have been running them for about 20,000 miles now. Ride wise they are great. Really comfortable. I do have 2 issues with them though....
1. They are a bit soft for my taste... I would like to firm up the car.
2. My cars stance has changed for the worse. The front sits high, and the rear sits low. I did some research after installing them and saw that they tend to raise the fronts, but why the rear of my car sits low I have no idea. I do have a 12" sub and hidden hitch installed, but together they are probably ~40lbs, not enough to make my car sag the way it does. I will post a pic tomorrow to show how my car is sitting.
So I am looking to upgrade one final time...
1. Koni Yellow - Hopefully stance would be corrected as I have seen no reports bout Koni yellow altering stance. I could also firm the car up a bit, and stock springs would retain some comfort. I could also run a mild lowering spring with these if i decided to...
2. Bilsteins - Read a lot of good reviews on these... however they are pricey. I am finding it hard to justify the high cost for shocks... might as well get coil overs. Where should I look to get the best price on these?
3. BC coil overs... these are the same price as a spring + shock combo. I know they lose travel vs stock suspeison, but how much travel is really lost? Will they ride somewhat comfortably on a soft setting? I am not going for ultimate performance so dont need KW V3's... just something that looks good and has performance atleast on par to stock.
Thanks for your input!
