Ok I have been in car Audio for 21 years, I have won SQL competions, so when i went to NOPI this year a judge and i sat in the car and adjusted away. So try it out, if you dont like it, Change it. Thanks, And let me know.
Bass F 80HZ
Bass + 6
Bass Q 1.25
Bass Ext on
Treble +6
Bal 0
F (fade) This is tricky, F+8 or f+6 The more you fade it to the back the less front stage you get, You want to hear the sound like you are standing in a concert and the band is in front of you, not behind you. With these setting you are not lossing any Bass so dont worry, just try it and you will see the difference
NF LV +3 or 4 depending on song
Amp Cntrl 2
HPF R 80 Hz
LPF NF 80HZ
Phase Nor
HPF F 100hz
HPF R 80
LPF NF 80 Hz
ok here is another tricky part, look at the sub woofer in the trunk and you will see two Dials, the first on should be set to where the Tick mark is pointing at 11oclock using the clock method. and the 2nd Dial should be set straight up at 12oclock
The first Dial is the one closest to the backseat, the second dial is the one closest to the rear of the car.
Now you can turn your stereo up to 25 and some songs up to 28. Lay the passenger rear seat down and you will love it.
Bass F 80HZ
Bass + 6
Bass Q 1.25
Bass Ext on
Treble +6
Bal 0
Amp Cntrl 2
HPF R 80 Hz
LPF NF 80HZ
Phase Nor
HPF F 100hz
HPF R 80
LPF NF 80 Hz
