I am struggling to get this car started after swapping engines. This is the first time I have ever swapped an engine, so I am not sure how to troubleshoot the problem and I could have overlooked something simple.
Background:
A few months back I bought an MSP with a blown engine. I swapped in a used MSP engine but it didn't work because the head was warped. I got a used, non-warped head and installed it but had poor compression because I missed the part in the service manual about the two sets of 90 turns on the head bolts. I took the head off again, put on a new head gasket, and tightened the head bolts correctly this time. I put everything back together and it almost started the first time, and since then it just cranks but doesn't ever catch.
Things I tried:
Different spark plugs
Different Battery (from my other MSPdefinitely working)
Here's a video of the first time I tried to start it: https://www.youtube.com/watch?v=dQmH71d2p0w
I definitely have fuel because the first set of plugs got soaked. I did a compression test and got about 60psi in each cylinder, but I am hoping the car just isn't cranking enough to get a good reading. I don't know how I could have that bad of compression with a new head gasket and a cleaned up head, and it's not just one or two cylinders that are low. The tach doesn't move at all when starting, but it sounds like it is cranking correctly. I've changed a few timing belts before, and I feel pretty confident it is in time.
Why would it almost start the first time but not subsequent times? What was that pop sound the second time I tried to start it? Any help is appreciated!
Background:
Things I tried:
