I am now running stock boost, and I have no power until ~5500 rpm. Most noticeable in 2nd gear. There is a major lack in power, then its balls to the walls until 6500 rpm. My afr is about 12:1, intake temps are nice and cool, boost holds steady at 7 psi. What the **** is going on? I have never had this problem before. There is an audible change in the engine as well. Its almost like vtec. In the wet my tires break traction at 5500 rpm. Its strange because before at 10+ psi power was immediate and died off after 5500 rpm. I have tried resetting the ecu, my spark plugs are new and gapped at .030. I am unsure if my ecu is flashed or not. I bought an msp ecu off a member here and have no idea if its flashed. There are no engine codes. I was reading a thread here where others explained the same problem, but a solution was never found. VICS and re-flash were what people were saying the most. Anyone have similar experiences?
