Hmmm, could very well be a relocated maf problem. Unless having your maf in pressure makes you engine go above 50% load sooner I cant see it making a difference. On a side note, 50% load is more like 15% load lol. You can often go over 50% load at -10 in.hg! My tps (throttle position sensor) reads at 0% throttle input, 10.6% and at 100% input ~86%. I am thinking that is how Mazda or whoever tuned the msp tuned it. This way, it will go over 50% load sooner, because it is reading more throttle then what is actually there, triggering the knock sensor sooner and at the same time changing the timing advance.
I have read somewhere that I am not the only person to have 10.6% as closed throttle tps reading.
I am thinking about making a coolant temp sensor clamp and clamp the voltage so the ecu see's only about 58 degrees, so the knock sensor is never used. I have been driving around for 2 weeks with no knock sensor, and haven't heard one ping yet, so I'm not too worried about that. above 45 degrees is when the ecu seems to go into closed loop, so anywhere between 46-59 should be good for a voltage clamp.
Realistically, the knock sensor is bulls*** anyways because it only monitors a narrow range (mostly closed loop), and not at all above 5k rpm, so it hardly does anything anyways.
