no power to a/c ? input requested.
exNeon
2003.5 silver msp
Hi all,
A few weeks ago i changed out my cabin air filter and that went as well as it can since im not a contortionist. However shortly after (the first hot day we had after the winter) my a/c was no longer working, though everything else seems fine.
The compressor does not turn on at all, I am thinking it might be electrical since I removed the fuse panel under the glovebox for the cabin filter install. Ive checked the fuses and relays, but they are fine.
I was hoping that somebody knows of anything else in that area that might be connected to the a/c for me to check. I am a bit suspect of a small connector to the left side of the passenger footwell. I dont have anything plugged into it, but in other pics i found people do. It is possible i just forgot to plug something in.
I plan to poke at it later today, but if somebody with that plug doesnt mind unclipping it and then trying out the a/c that would be very helpful.
so in case anyone was wondering, it was the 2 wire clip in the passenger kick panel area was unclipped, and apparently is the lines to the a/c
