No Boost?!?!?!
Everyone that looked at my car and messed with it said my wastegate is perfect, soI think I'm gonna try and go with better injectors. Any recommended?
i wouldn't get 440s unless you have something to tune it with. msps run rich enough on the stock ecu. i have my stock injectors if you wanna swap them to see if that's the problem. i have a boost leak tester we can use to make sure your plastic piping isnt cracked too
Yes please!
If your stock injectors are supose to make your car run rich, maybe the one's you currently have are just old and dirty, not giving your car enough fuel making you run lean.
Note: When you're having J_Naoto make sure he dosn't adjust your wastegate to turn up your boost. :)
I think I may have fixed it. Took the two vac lines off of the either VTCS or VICS solenoid (whichever one is the leftmost)on to of the intake mani, The car is running normally now. Still don't know about the lean A/F though. Need a guage.
