No Auto Window Up/Down
Pitter
2020 CX-5 Signature Azul Metalico
Contributor
Took my Signature in yesterday for the 10,000 kilometer service. As I was driving home I realized the auto up/down feature the windows only worked on the driver's window. The other three windows worked normally but without the auto function. What could they have done and can I reset somehow so they all work? Or have to go back to the dealer?
Roll the window all the way down, then roll it up all the way and keep holding the switch for 3-5 seconds after the window is closed. I don't think there is a beep, but that should re-initialize the auto function. You'll have to do this for every door individually. This is the process for NA models, hopefully it's the same for the Mexico market. If it doesn't work, you can try calling the dealer so that they can walk you through the correct reset procedure over the phone.
Usually this has to be done when the battery has been disconnected for a while.
Thanks I ll try that. Makes sense. My saved seat position was gone to so yes must have disconnected the battery.
